Here’s another question,
If I save a template in Freeway Express 4 will it be able to be installed and work in Freeway Pro 4?
Many Thanks,
Fergus T
Yes, it will. But it will be limited by the feature set of Express.
If that makes any sense.
As an example, all the templates that ship in Freeway are designed to
work with Express, but they also work in Pro. So, if you create
templates using Express, they will work in Pro, but the Pro-only
features (CSS, fancy graphic formats, etc) won’t work.
Heather
Design and build responsive websites, email newsletters, galleries, and color palettes with Freeway, Exhibeo, and Chroma – awesome design software for the Mac.
“Freeway - Web Design for All”
Okay, thanks very much for the fast reply. Much appreciated!
Fergus T
Sometime around 20/5/08 (at 16:11 +0100) Heather Kavanagh said:
if you create
Sorry to be a picker of nits, but don’t you mean “won’t be able to be
included in the template”?
k
Nit Picker: A little known part of the Mac OSX.
Yes, you are quite correct.
As an aside, I’m trying to find time to develop some snazzy Pro
templates which will feature all the Pro goodness.
However, time is not something I have in abundance right now. =o(
Heather
