Hi, I am just starting in converting my existing webpage into a Freeway based webpage.
I bought the Backdraft template and just uploaded a simple site with just the responsive menu header.
I adjusted the width for all modules to 1840 px, because I would like to have the page working about to screen resolutions of 1920 px.
If you check this simple example on http://www.offroaddance.eu, everything looks fine, but if you make the browser windows smaller and smaller, after some time a scrollbar is visible at the bottom of the browser window. This stays until the minimum width of the page.
On Calebs page, this effect is not visible.
What I noticed, is, that there is coming a grey zone right to the menu bar, after I am getting under a certain page width.
How can I get rid of this, so that this works without this scrollbar.
I think, I did not change anything in the configuration.
I just started a new page, changed the max width to 1840 px , copied the responsive menu header into the page and published it.
Thanks in advance for your help,
Christian
