Is this possible tom remake in freeway?
Thnx.
Thnx.
Hi David,
what makes you hesitating? There is on the first view nothing in that let us perspire.
Let’s say it that way:
The ugly “unproportional” background slideshow you could do with Tim’s (pretty :-)) background slideshow that can be found here:
http://www.freewayactions.com/test/background-slideshow/
To make it as unproportional as in the example you have to scale the images first (maybe about -45% in the height) to get 1024x450, cause Tim’s action is working proportional (looks like this: http://www.kimmich-dm.de/bgslideshow/bgslides.html )
The rest is resizing all images, maybe if necessary think of small CMS (WebYep for example cause it is Joomla and customer want to have it) and you have a quick rebuild of the site.
… and bit of modernity won’t hurt
Hi,
Thanks for the quick reply, the thing I found difficult were the seperate languages. Do I have to make 4 copies of the site per language. Or can I use a different option? I was planning of using webyep so that no problem. Is there a way to make a random background instead of the slideshow. So everytime you look at the site a new image appears.
Hi David,
languages is a good point. I remember a request of Max that never been answered, so …?
In here there should be some automatic translation but these won’t work and if you plan wy you should really think about different files.
Random Background Walter did an action I’ve never tested that can be found here:
http://actionsforge.com/projects/view/93-random-backgrounds
One more question,
If you look at the menu. It is all css, how can I do the same thing in FW. If you look you will see that that the dotted line beneath it changes from color to. I’ve looked at the css menu action and couldn’t create the same menu. Also with the insert of the submenu.
