I have had to move my navigation into a CMS and the radio buttons that show/hide the corresponding div have stopped working. I suspect this is because it is not being activated by the prototype code.
I have the radio buttons pointing to the right div (femalemenu and mixedmenu) but cannot spot what might be getting missed with regards to the js.
The area is on the right column half way down.
http://www.newyoubootcamp.com/dev/nav-test.html
If anyone has a sec can they take a look and see if anything is obvious.
Thank you
