Quark? That’s a bit of a pen and paper approach, but if it works…
I would use Filemaker myself.
Not sure when it changed, but whereas FM9 encrypts data if you
password it, FM6 just sets a ‘please don’t reveal this without a
password’ flag. You can extract a lot of the contents of a passworded
FM6 from the command line, just you cant be sure which relates to
what. FM9 encrypts it.
I do use FM6 for passwords, but keep the file on an encrypted disc image.
HP-UX specialist of hpUG technical user group (www.hpug.org.uk)
email@hidden www.ivdcs.co.uk
I think I know what you mean. Sometimes, if I don’t disconnect from a
server before closing the lid and going to another network, QS will
hang when I first attempt to use it. I’ll then get a, “You are no
longer connected to the following servers” dialog with a disconnect
button. Once you disconnect from the/all the servers then everything
starts working.
Joe, on a slightly different note: I started using QuickSilver last
year, and absolutely loved it; I got so I could hardly work without
it!
Then I noticed that after a period ranging from one to three days,
my Finder would ‘freeze’. I couldn’t drag icons on the Desktop,
although the contextual menus worked fine, and I could send them to
the Trash using the keyboard shortcuts; just couldn’t drag them
around. Force-quitting the Finder fixed it, but it stopped me using
QuickSilver. I traced the problem to QuickSilver by a process of
elimination.
Did you ever come across this and, if you did, do you know a
solution? I’m running Leopard now, although I was running Tiger
then. Perhaps I’ll give it another go …
a server before closing the lid and going to another network, QS
will hang when I first attempt to use it. I’ll then get a, “You are
no longer connected to the following servers” dialog with a
disconnect button. Once you disconnect from the/all the servers then
everything starts working.
I must say I haven’t noticed it recently though.
Thanks for the feedback Joe. I rarely connect to other servers, so I
don’t think it was that in my case. I’ve downloaded a fresh copy, and
am tryintg it again. Actually, since going to Leopard, I’ve had these
Finder ‘freezes’ without running QuickSilver, so I figure if I
occassionally have to restart the Finder, I might as well be getting
the QuickSilver goodenss anyway …
Actually, since going to Leopard, I’ve had these Finder ‘freezes’ without running QuickSilver, so I figure if I occassionally have
to restart the Finder, I might as well be getting the QuickSilver
goodenss anyway …
Could be spotlight, that can be a pain when indexing.
I use Soho Notes. It started as Sticky Brain and now has become Soho Notes. Backups everytime it starts and I’ve got everything in there. From passwords to serial numbers to quotes to tips to credit cards to notes.
You can also sync many machines to the same password master file. Just check out the demo - it’s totally awesome! (ps I am not actually from the valley)
