I tried applying the remote resources action to my new blogger template and it gives me an error. I have no scripty or proto stuff added to it, it just doesn’t want to cooperate. Is there a way (without manually going in) to remotely add links in there like the action once did?
Am I under the assumption then that the base HREF we need to put into the Freeway Upload setting is where our Resource folder, if it is off another server space, needs to be put in and not the actual blogspot address like it says on the Softpress site?
I just want images I use to be linked from my blogspot space and loaded from server space I have elsewhere. I currently have to go in manually and add the address, is there an easier way?
The address that you need to use in the Web Address field of the
upload dialog is the address that you are uploading to. This address
is then used in the base tag on your Blogger page so that any images
you have used on your page can be referenced correctly. This is, in
effect doing the same thing as the Remote Resources Action.
I hope this helps.
