Try looking at this… Flowtype.js: font-size and line-height based on element width ow.ly/oJdyu
David Owen
On 11 Sep 2013, at 14:42, Walter Lee Davis email@hidden wrote:
When you lengthen a line of text (physically lengthen it, that is) without also adjusting the leading and/or font size, you end up with a lot more words on a line than can be comfortably read. The eye frequently gets lost on the return trip to the next line, and reading speed and comprehension plummet.
I spent some time this morning looking into the “text zooming on mobile Safari on rotate to landscape”, and I’ve tossed together a solution.
In the document setup, go to the mobile tab and replicate these settings:
ViewPort width = Device Width
ViewPort Height = None
Page can be Scaled on mobiles = checked
Initial Scale = 100%
Minimum Scale = 25%
Maximum Scale = 160%
Then, this line needs to be added to the CSS:
body { -webkit-text-size-adjust: 100%; }
The result is that the text won’t enlarge in mobile Safari when you rotate the device, yet you can still pinch to zoom and ⌘+ to zoom the text in desktop Safari.
