Results per page
Been doing some light(ha!) reading in the PHP and MySQL monster book
looking for a way to limit the number of results shown per page. I’ve
tried a few things but I keep breaking the [mar] app.
What I want to do is take all the entries on the admin page (follow
the link below) and break it down into blocks of 10 with the
corresponding “next” and “previous” navigation.
http://www.anoptic.com/MAR/client
dynamo mailing list
All of the basic MAR “finders” support OFFSET and LIMIT arguments. If
you are returning your results in ID order, you can simply set up a
route like
http://example.com/widgets/next/123
where 123 is the ID of the last element in the current result set, and
then have your finder look like this:
$widgets = ActiveRecord::FindAll('widgets','id > ' . $id,'id ASC',10);
//loop through your results and make your list of links to each
//then find the last element in the results and use that to construct
the
//next link, and vice-versa for the previous link
$last = array_pop($widgets);
$next_link = $last->link_for('next','name','full','next');
$first = array_shift($widgets);
$previous_link = $first->link_for('previous','name','full','previous');
If you’re returning results in a different order, then it becomes more
complex. You have to figure out how many “pages” of results you will
have, then use this sort of route to navigate:
http://example.com/widgets/page/4
This example shows you how to construct the links and how to use the
result.
$total = ActiveRecord::Count('widgets');
$pages = ceil($total / 10);
$pages_array = range(1,$pages);
foreach($pages as $k=>$page){
	$class = ($page == $id) ? ' class="here"' : '';
	$pages_array[$k] = '<a href="widgets/page/' . $page . '"' . $class .
'>' . $page . '</a>';
$page_links = implode(' | ',$pages_array);
$offset = $id * 10;
$widgets = ActiveRecord::FindAll('widgets',null,'name ASC',10,$offset);
I’ve tried a few things but I keep breaking the [mar] app.
dynamo mailing list
It’s throwing a couple SQL errors. The case ‘index’: <http://pastie.org/549966
Notice: Undefined variable: id in /Applications/MAMP/htdocs/MAR/admin/
controllers/mar_controller.php on line 19
Warning: MyActiveRecord::Query() - query failed: SELECT * FROM mar
WHERE id > ORDER BY id ASC LIMIT 0, 10 with error: You have an error
in your SQL syntax; check the manual that corresponds to your MySQL
server version for the right syntax to use near ‘ORDER BY id ASC LIMIT
0, 10’ at line 1 in /Applications/MAMP/htdocs/MAR/admin/lib/
MyActiveRecord.0.5.php on line 200
Fatal error: MyActiveRecord::FindBySql() - SQL Query Failed: SELECT *
FROM mar WHERE id > ORDER BY id ASC LIMIT 0, 10 in/Applications/MAMP/
htdocs/MAR/admin/lib/MyActiveRecord.0.5.php on line 621
dynamo mailing list
From what I can see the id in the MySQL is empty… WHERE id > ORDER
should look something like WHERE id > 24 ORDER
HTH
admin/controllers/mar_controller.php on line 19
LIMIT 0, 10’ at line 1 in /Applications/MAMP/htdocs/MAR/admin/lib/
  • FROM mar WHERE id > ORDER BY id ASC LIMIT 0, 10 in/Applications/
    MAMP/htdocs/MAR/admin/lib/MyActiveRecord.0.5.php on line 621
dynamo mailing list
Yeah, I thought (and tried) that also but it just throws a different
set of errors.
dynamo mailing list
It would be best then to see what those errors would be because this
one ‘as you say’ is probably going to throw an error different to the
one that would be thrown when it has a value… and that would
probably be the one to look at. :slight_smile:
set of errors.
ORDER should look something like WHERE id > 24 ORDER
dynamo mailing list
dynamo mailing list
Yes, that would make sense, wouldn’t it? I’ll post it tomorrow, I’ve
had my fill of looking at code today. My blood-shot eyes have had
enough.
T.
the one that would be thrown when it has a value… and that would
dynamo mailing list
Do you have a normal routing.php in your stack? Does it have a section
devoted to finding the ID from the URI (always the third segment) and
setting $id to that?
dynamo mailing list
dynamo mailing list
Try adding this as a test (not a substitute for fixing whatever is
wrong in routing.php)
if(!isset($id)) $id = 0;
dynamo mailing list
dynamo mailing list
Yes, I have a routing file but I don’t see anything specific to
finding the ID from the URI.
routing.php http://pastie.org/550022
T.
section devoted to finding the ID from the URI (always the third
segment) and setting $id to that?
dynamo mailing list
I’ve commented the relevant lines, and added a refinement at line 16
which should catch your error in all cases.
T.
dynamo mailing list
dynamo mailing list
Duh!
http://pastie.org/550087
forgot the actual link…
dynamo mailing list
I’m feeling like the village idiot at the moment (where did I put my
dunce hat anyway?). I updated routing.php but still get errors. I
haven’t setup the actual “next” and “previous” links yet so I’m
guessing that the 3rd error below is referring to that but I’m not
certain. I think I’ll put it all back the way it was and step away. My
head is obviously not where it needs to be to do this and I’m sure it
shouldn’t be this difficult.
Thank you for your help.
routing.php on line 17
Warning: array_pop() [function.array-pop]: The argument should be an
array in /Applications/MAMP/htdocs/MAR/admin/controllers/
mar_controller.phpon line 23
Fatal error: Call to a member function link_for() on a non-object in /
Applications/MAMP/htdocs/MAR/admin/controllers/mar_controller.php on
line 24
dynamo mailing list
