Julie1
(Julie)
May 31, 2010, 1:34pm
21
I had done nothing, I reduced the size of that file and the header.
And I worked on the form
actually that is what I did - I copied and pasted…
J
On May 31, 2010, at 8:15 AM, DeltaDave wrote:
That GR Wellness logo is huge! Well over half a Meg
Dimensions 505 × 576
File size 655.36K
Did you do something with the index page because it has stopped repositioning/jumping?
As to the form - I would add another empty column between the existing (for padding) and increase the width of the RH column also increasing the width of the entry fields so that they are all about the same width as your biggest - the Health/Wellness Facility dropdown.
There is also no reason you cannot use the same form for both Contact and Request a Quote with some slight alts.
Gray_Owl
(Gray Owl)
May 31, 2010, 10:55pm
22
On 31 May 2010, 1:39 am, swimmer35 wrote:
Thanks Lee and Laura! it means alot.
Ok here is the question now - how do I fix that??? the lightbox and the form? should I make the table bigger?
Thank you!!
Julie
Hi Julie
As for your form, I don’t know as I use ‘Forms to Go’ and the ‘Form Element Style’ action. Don’t have any problems with that set up.
As for the ‘Scripty Lightbox’ I posted a thread on it http://freewaytalk.net/thread/view/70465#m_70547 also look at brutontown.co.uk as this is done with 'Scripty Lightbox" and it doesn.t work. I dont know why??
Regards
Lee
Julie1
(Julie)
June 1, 2010, 1:37am
23
The form I fixed - thank you to DeltaDave
I see the instructions from Walt - I will do them in the am. I just looked at your test - odd.
SO Walt, any thought on either of our pages??
J
Thank you!!
Julie
Hi Julie
Regards
Lee
Julie1
(Julie)
June 1, 2010, 1:44am
24
here is another question by a fellow FWT user… about my blog
.Is there any way that your ‘Paper’ background page could expand, as your comments get longer.
I was wondering the same thing so, is there?
Thank you
Julie
http://www.grassrootsweb.net
J
Thank you!!
Julie
Hi Julie
Regards
Lee
waltd
(Walter Davis)
June 1, 2010, 12:19pm
25
You’ve made your “background” as a fixed-size image, so no, it can’t grow to fit the height of the comments area. What you need to do is set it as a tiling background image and then make sure that the body of the post and the comments are both inside the HTML box that you apply that background image to. Finally, delete the height from the HTML box using the Inspector, and the page should flex vertically to fit the available content.
Julie1
(Julie)
June 1, 2010, 4:19pm
26
worked perfectly!!
Thank you Walt - you are amazing.
and thank you Lee for inspiring the question
Julie
Ian
(Ian)
June 1, 2010, 4:23pm
27
how do we unsubscribe from post notifications ?
not sure how to do this
Julie1
(Julie)
June 1, 2010, 4:25pm
28
there should be a link saying unsubscribe…
Thank you Ian…
Ian
(Ian)
June 1, 2010, 4:28pm
29
i, of course, looked for this
but there isn’t one
Julie1
(Julie)
June 1, 2010, 4:34pm
30
I am off line emailing you a screen shot where I see it.
I figured you did - It took me a bit to find it too.
J
but there isn’t one
Ian
(Ian)
June 1, 2010, 4:48pm
31
julie
i think it’s for an rss feed
i receive post notifications of topics i subscribe to
if i am wrong can you send me a link ?
btw
i think your site looks good
just too much happening at moment
Julie1
(Julie)
June 1, 2010, 4:55pm
32
Thank you Ian -
I totally understand
I emailed you w another screenshot .I do think it is for email.
J
On Jun 1, 2010, at 12:48 PM, Ian wrote:
julie
btw
Ian
(Ian)
June 1, 2010, 5:26pm
33
julie
can you mail me a link to the page you are seeing ?
Julie1
(Julie)
June 1, 2010, 5:36pm
34
here is a link -
http://grassrootsweb.net/Blog/2010/May/index.html
it all is happening right on my site
J
On Jun 1, 2010, at 1:26 PM, Ian wrote:
julie
