roll over to target show /hide image problem
I have created a roll over on an item which is pointing to an target show/hide image , which shows contact us on my main page , the roll over have a click which is link to mail to email@hidden.
The roll over works fine (located on the last blue bar) , the link too the problem is when i click it is opening the mail window fine but the Contact us image remain in the page , i would like it to disappear automatically when i click on the roll over and the email window open , i tried to figure it out for a while without any success .
You can check it at http://www.patrickmimran.com.
Thank you for your answer
Patrick Mimran
In the Rollover Action there is a column for the click event, simply set it to your “normal” image or un-check all images and you should be done.
