Sometime around 15/1/08 (at 16:16 -0500) shybuckstudio said:
my goal is to create a red square as the normal item and have a
green square with words as the mouse over. I have made the words as
a GIF but can not seem to combine the green square with the words as
the roll over… thanks for your patience with this neophyte
The problem is probably because your objects are layered. This makes
them ‘float’, in a sense, in the page layout, and the top one won’t
be able to connect with the one below it in order to use it as part
of the rollover construction.
There are two ways around this…
The first is simply to UNcheckthe ‘Layer’ checkbox in the Inspector
palette. Do this for both items, then apply the Rollover action. You
should now be able to pick which item is visible for each state from
the Actions palette.
But if you want your rollover to be managed within a layer (i.e. a
CSS-controllable ‘div’ element) rather than be made as part of a
background table structure, select both items - drag-select across
them both is easiest - and choose Group from the Item menu. This
wraps the items in a new HTML box container. This can be set to be a
‘floating’ layer, but the two items inside can still be set to NOT be
layered. That allows them to act together in a rollover.
This object now takes a little practise in moving around. Just a
little mind you - but note that clicking inside it will select the
top-most object inside the group, not the ‘parent’ group object
itself. To do that you have to click on the edge of the thing -
that’s what to grab and drag. Or nudge with the arrow keys.
Okay, next step… the graphic text. You DID make this in Freeway,
right? That’s so much quicker and more flexible than greating an
actual graphic document first and importing it. I just mention this
because you said you ‘made the words as a GIF’…
And BTW, there’s a nice trick for editing text in boxes if you’ve
stacked items together. Rather than dragging your stack apart to
select something lower down, hold down the Command (Apple) and Option
(Alt) keys and click. Each successive click selects the next-lower
item. Look at the Inspector palette to see which item is selected;
the fill colour often helps reveal this.
Once you’ve selected your graphic box below the top one, hit the
Enter key. This ‘opens’ the selected item, switching it to text
editing mode. Just type, or choose Select All first to select
existing text.
k
