On Nov 9, 2011, at 6:19 AM, tonzodehoo wrote:
Hello Walter, Thanks again for this.
I’m working my way through the sprite set up just now. Wanted to check where I’d place the Carousel tab action as its to work the Carousel that I’d like to have such a menu as this rather than navigating to pages.
An instance of Carousel Tab is applied to each graphic box that you want to turn into a direct navigation control, used to select a particular tab out of the Carousel and cause it to scroll into view.
When you mention the GIF image are you talking about this in the context of the sprite set up or as part of the original Carousel tab issue?
Carousel Tab requires a graphic box as its host. If you draw an empty graphic box and apply the Action to it, Freeway doesn’t publish the image, so the effect is broken. If you import an image into that graphic box (in this case a 1x1 clear GIF) and stretch it to fit the box, then it does publish the image, and the sprite effect has somewhere to go.
The Sprite menu is one I’ll definitely be using. Do you think its one that might be emerging as an option for a menu action at all?
I floated this in the Action list several years ago, when I developed the example page. Paul Dunning made the CSS Rollover Action, which does a variation on the sprite idea, but doesn’t actually do the whole thing. The issue is that in order to do what sprites really do best, you must conjoin all of the images into a single block, but Freeway doesn’t expose anything to the Action writer that would make that possible (even though Freeway’s graphic engine has done this trick since version Nought). Without some way to stitch all the images together, the Action wouldn’t be very useful for the lay user.
It should be possible to add this to the core of Freeway, in fact it lends itself to that very well, since it can be expressed in some simple algorithmic rules (if an image is below such-and-such dimensions, add it to the sprite block and replace it with a clear GIF spacer), but Softpress have a lot of fish to fry, and only so many pans, so I doubt it’s going to see the feature list any time soon.
All the best for now
