I have a 2-image rollover that works fine… until I place it in a CSS box. Once I put the rollover in the CSS box, it no longer works. The link works, but the image doesn’t change.
How are you placing the rollover in the box? Is it inline, or simply a child element (drawn over the top of the parent box)?
If it’s inline, you’ll need to use the old-school Parameters interface in the Rollover Action. You will need to take your “over” image and export it from Freeway at precisely the same size as your normal image, then use the Rollover picker to select it.
Rollovers DO work on inline images, it’s just not as simple as stacking and grouping a pair of images and applying the Action.
You guys are amazing!! Thanks Walter!!! I swear I didn’t see that Parameters tab for the life of me. Per your instruction, I got it working in about 10 seconds.
Yeah, I’m used to stacking two images, then creating the rollover. It’s nice to see the parameters and see what they actually do.
