No. Here’s the publish cycle:
You place an image on the page*. The original is NEVER touched, only
read in and manipulated within Freeway.
If you scale, crop, merge or otherwise manipulate the image in
Freeway, then a copy is made of the original, and this copy is
dynamic. If you change your layout, or if you change the quality or
compression method, then a new image will be created from the
original with the new settings. Your original image is never
changed in any way, but the copies that Freeway creates and uploads
are changed depending on how you may have set your preferences.
“When in doubt, throw it out” is Freeway’s watchword. If you make a
change to a page, all elements of that page are re-generated from the
current settings. That means the HTML, the scripts, and the images.
Believe it or not, this is a good thing, because it means you are not
stirring the same swill around hoping it will turn to gold, like
Dreamweaver.
*note that Freeway allows you to place an image in an HTML box, also
known as Pass Through. Images placed this way are never re-
compressed, they also cannot be cropped or manipulated in any way.
It’s up to you to make them Web-ready.
On Jan 30, 2008, at 8:21 PM, alano wrote:
Wait a minute. Are you saying that everytime I test my site FW
publishes it and each time the images are scaled and re-scaled?
Does this mean that every time I publish I loose quality?
-Dooki
