Rollover Problems
Can somebody explain what is going on here?
I have applied 3 rollover to 3 grouped items. When I review the Normal, Mouse, and Click in the Actions window everything looks fine. In Preview or Safari it is not working properly.
When clicking on the Free Products, Consumer Services, or Business Services, the text should change to brown and the box to the right should show with a tab around the proper text item.
This is driving me crazy. I am either doing something wrong or there is some conflict going on.
Thanks.
http://reeltimedvd.com/new_site/index.html
I suspect that your pages links are not changing. I noticed that when you click on a tab the url stays “index.html” but gets an # sign added. How did you set up your links?
Not sure why you are asking about links. I didn’t think links had anything to do with rollovers. If I am wrong, let me know.
The other links on the page were created by Edit:Hyperlink…
Sorry George, I think I misunderstand what i’m supposed to be looking at.
Looking at your page there are tabs across the top with the same labels as the tabs in the middle so i’m confused what to look at. Using the Developer tools in Safari, and looking at the central tab labeled Consumer Services shows there are multiple (7) copies of the same graphic with two of them labeled “consumerlayer” and five of them labeled “consumerlayera”. Same goes for some of the other objects.
How about making a separate page just to work out your rollovers on then copy and paste the results once they work properly to the page you need them on?
Thanks. I will take a look. I don’t understand how there can be multiple copies of the same graphic. Doesn’t FW automatically make sure items do not have the same label?
I will try your suggestion.
All right.
I’ve tried every single combination of Target Layer/Rollover I can think of to get this to work and I am defeated.
Either what I am trying to do is not possible, or I am incorrectly setting my restore settings.
Surely this must be possible and not this hard. I must have a mental block because my head feels like it is going to cave in.
Any help would be great.
