Hi Walter,
Just wondering if you know of any sites that explain the Ajax side of things with regards to Carousels.
Thanks.
Tony.
Hi Walter,
Thanks.
Tony.
Here’s one that does it:
http://docs.prototype-ui.com/rc0/Carousel
I know there was another one I saw when I was researching options for
my Action, but I can’t find it now.
Basically, what you would want in terms of Ajax is what’s known as
“lazy loading”. Your Carousel would load up only two panes, then load
the third (and so forth) when you request the second one to scroll
into view. Each time that the next part loads, it would need to update
the variables in the JavaScript to tell it how wide the inner sliding
element is. You could not use tabs with this construction, because
when the page loads, it doesn’t know how many options there might
eventually be. Or you could use tabs, but you would have to load them
lazily as well.
On your server, you would have a script (PHP, Ruby, whatever) that
constructed a pane. This would need to come out of a database or maybe
just a directory listing. When this script gets its initial request,
it would pop out two panes’ worth of HTML and send it along. It would
also set a counter to 2, and when it next gets a request, it would
send number 3 and increment the counter, etc. In JavaScript, in the
browser, clicks on the “next” button would advance the carousel as
always, but would also call Ajax.Updater in the background to request
the next pane of content.
On Feb 1, 2009, at 9:19 AM, Tonsils wrote:
Hi Walter,
of things with regards to Carousels.Thanks.
Tony.
Hi Walter,
I’ve just been trying to incorporate a jQuery Lightbox feature into my carousel. Unsure what I could be doing wrong but prior to applying the Carousel action, I’ve managed to get the lightbox feature to work, by where a click on a thumbnail and the jQuery lightbox feature kicks in.
On top of this, I apply the Carousel action and instead of my thumbnail utlising the jQuery lightbox, it actually opens the picture in over my original page of thumbnails.
Just wondering if there would be any conflict between the carousel action and the jQuery Lightbox.
Thanks.
Tony.
It’s best not to mix high-level libraries like jQuery and Prototype.
Carousel uses Prototype. If you want to use jQuery elsewhere, you’ll
have to use a different carousel effect that’s based on jQuery. (They
exist, and you shouldn’t have too much trouble exchanging my Action-
ized method for a hand-coded jQuery approach if you’ve already gone
down that particular rabbit-hole.)
On Feb 16, 2009, at 8:52 AM, Tonsils wrote:
Hi Walter,
lightbox feature kicks in.On top of this, I apply the Carousel action and instead of my
picture in over my original page of thumbnails.Just wondering if there would be any conflict between the carousel
action and the jQuery Lightbox.Thanks.
Tony.
Thanks Walter - understand.
Just wondering if you know of a good jQuery Carousel at all?
Tony.
I can’t recommend one from personal use, but if you google jquery
carousel, the first hit looks really interesting and well documented.
Tony.
this carousel and tabs looks as though it might be what I need as I outlined in the thread I posted earlier today.
could I put media players in the panes?
Thanks again but I was just wondering, with the whole jQuery and Prototype combination possibly being an issue, would the jQuery function:
jQuery.noConflict( );
assist in any way?
Thanks.
Tony.
Yes, it should work, although there are reports of some instances
where there is “leakage” from the hidden part of the carousel when the
content includes Flash. (I haven’t seen this myself.) You should try
it out, test it in a number of different browsers to be sure.
outlined in the thread I posted earlier today.could I put media players in the panes?
Yes, that’s what it’s for. I haven’t researched this much myself, but
basically what this does is replace the $() function (shorthand for
findElementById()) with $jQuery() or something like that. Since
Prototype also has a $() function, used for the very same purpose, the
two clash otherwise. The part I don’t know is whether enabling
noConflict() means that you would have to go through any other library
code that invokes jQuery’s $() function and replace those calls with
$jQuery().
function:jQuery.noConflict( );
assist in any way?
Thanks.
Tony.
Unfortunately I can’t seem to get the carousel working with the jQuery Lightbox plug-in.
Would really appreciate some help. Here is a snippet of code from the page source, including the jQuery.noConflict() statement:
var $j = jQuery.noConflict();
$j(document).ready(function() {
$j('#gallery a').lightBox();
</script>
<style type="text/css">
/* jQuery lightBox plugin - Gallery style */
#gallery {
background-color: #444;
padding: 20px;
width: 94%;
#gallery ul { list-style: none; }
#gallery ul li { display: inline; }
#gallery ul img {
border: 5px solid #3e3e3e;
border-width: 5px 5px 20px;
#gallery ul a:hover img {
border: 5px solid #fff;
color: #fff;
#gallery ul a:hover { color: #fff; }
</style>
<div id="item1" style="position:absolute; left:5.19px; top:5px; width:710px; height:589px; z-index:1">
<div id="gallery">
<ul>
<li>
<a href="photos/image1.jpg" title="screen shot 1">
<img src="photos/thumb_image1.jpg" width="72" height="72" alt="" />
</ul>
<div id="galleryContainer1" class="section"><div style="position:relative; width:719px; height:594px; background-color:#fff; overflow:visible">
<div id="item1a" style="position:absolute; left:5.19px; top:5px; width:710px; height:589px; z-index:1">
<div id="gallery">
<ul>
<li>
</a>
</li>
etc
Sorry - forgot to mention that the jQuery Lightbox plug-in works but the Carousel side of things doesn’t.
Tony.
Please send a link to the page, I can inspect it in Firebug and see
what’s going on.
the Carousel side of things doesn’t.Tony.
Unfortunately I am unable to host page.
With regards to Firebug, are you able to let me know what I should be looking for, to see, if I can detect anything.
Thanks.
Tony.
If you install Firebug, enable it, and visit the page in Firefox (naturally) you will see a little red (x) in the bottom-right of the browser frame. Click it, and see what it says. Copy and paste it into a new message here, and we’ll see what’s up.
Hi Walter,
There was a red(x) in the bottom but unfortunately nothing came up.
Sorry, but I have decided to add the whole “View Page Source” code in this thread:
</script>
#gallery {
padding: 20px;
width: 94%;
#gallery ul img {
color: #fff;
</style>
screenshots
<div id="gallery">
<ul>
<li>
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 2">
<img src="photos/thumb_image2.jpg" width="72" height="72" alt="" />
</a>
</li>
<li>
<a href="photos/image3.jpg" title="screen shot 3">
<img src="photos/thumb_image3.jpg" width="72" height="72" alt="" />
</a>
</li>
<li>
<a href="photos/image4.jpg" title="screen shot 4">
<img src="photos/thumb_image4.jpg" width="72" height="72" alt="" />
</a>
</li>
<li>
<a href="photos/image5.jpg" title="screen shot 5">
<img src="photos/thumb_image5.jpg" width="72" height="72" alt="" />
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 6">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 7">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 8">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 9">
</a>
</li>
<li>
<a href="photos/image3.jpg" title="screen shot 10">
</a>
</li>
<li>
<a href="photos/image4.jpg" title="screen shot 11">
</a>
</li>
<li>
<a href="photos/image5.jpg" title="screen shot 12">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 13">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 14">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 15">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 16">
</a>
</li>
<li>
<a href="photos/image3.jpg" title="screen shot 17">
</a>
</li>
<li>
<a href="photos/image4.jpg" title="screen shot 18">
</a>
</li>
<li>
<a href="photos/image5.jpg" title="screen shot 19">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 20">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 21">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 22">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 23">
</a>
</li>
<li>
<a href="photos/image3.jpg" title="screen shot 24">
</a>
</li>
<li>
<a href="photos/image4.jpg" title="screen shot 25">
</a>
</li>
<li>
<a href="photos/image5.jpg" title="screen shot 26">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 27">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 28">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 29">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 30">
</a>
</li>
<li>
<a href="photos/image3.jpg" title="screen shot 31">
</a>
</li>
<li>
<a href="photos/image4.jpg" title="screen shot 32">
</a>
</li>
<li>
<a href="photos/image5.jpg" title="screen shot 33">
</a>
</li>
<li>
<a href="photos/image1.jpg" title="screen shot 34">
</a>
</li>
<li>
<a href="photos/image2.jpg" title="screen shot 35">
</a>
</li>
</ul>
<div id="gallery">
<ul>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
</ul>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
</ul>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
<li>
</a>
</li>
</ul>
Hope this somehow helps as I mentioned, when I clicked on the red(x), no errors appeared.
Thanks.
Tony.
See if you can tweak the order of these so that jquery.js and its
lightbox load after prototype and scriptaculous. That’s where the
problem is happening. The problem happens before noconflict can sort
it out, because the load order is setting up jquery to “win”.
On Feb 22, 2009, at 8:08 AM, Tonsils wrote:
<script src="Resources/jquery.lightbox-0.5.js"language=“JavaScript” type=“text/javascript”>
Thanks again Walter - will try it out and let you know how I go.
Tony.
Hi Walter,
Did what you suggested and even managed to remove the error red(x) on the page but unfortunately I can’t seem to get the lightbox component working as when I click on a photo, it overwrites the picture box and opens on a new page.
Lightbox is completely ignored but carousel works.
Here is part of the code again but I think I have to accept that I can’t use the two frameworks together.
</script>
#gallery {
padding: 20px;
width: 94%;
#gallery ul img {
color: #fff;
</style>
Thanks for all your help with this Walter.
Tony.
