Rollovers, slave images and links
My page at http://www.VirtualVermont.com/calendar/index.html works exactly as it should: mouse over the different regions on the map, the rollover action highlights the region,the name of the region appears above the map via slave image, and a click brings you to the calendar page for that region. This page is made in FWPro 3.5.15.
Now cut to http://www.macajow.com/calendar/index.html (I am using this domain to rebuild the site in FWPro 5.3 prior to going live).
Same page, converted to FWPro 5.3. It works properly when previewed in browser, but the uploaded version does nothing. No rollovers, no slave image, no links to the calendar pages.
Both sites are on the same server.
Any suggestions?
Matt
Looks like the javascript is not loading properly. Also, there is a missing link to /calendar/vvis/index.html
I’m not so concerned with broken links at the moment. Any ideas as to what might be happening with the javascript?
Further experimentation:
I brought this same page from my live domain, and it works fine as http://www.macajow.com/calendar/index2.html.
I put the non-functioning page at http://www.VirtualVermont.com/calendar/index2.html and it works properly.
So, to recap:
http://www.macajow.com/calendar/index.html (produced in FWPro 5.3) works fine locally and as http://www.VirtualVermont.com/calendar/index2.html, but it does not work in the macajow domain.
http://www.VirtualVermont.com/calendar/index.html (produced in FWPro 3.5.15) works fine both locally and at http://www.macajow.com/calendar/index2.html.
The 3.5.15 page works locally, and at both macajow and virtualvermont.
The 5.3 works locally and at virtualvermont, but not on macajow.
Matt
I had an issue when I moved to FW5 also. I had to go back and check all of my rollovers and target images, and make sure none had migrated to FW5 as layers. FW5 worked fine after a few tweaks of the page.
