This is a great program, which coming from a long time illustrator user (since 1988) is high praise.
There are just a few things I miss, like being able to choose the origin points visually that objects rotate, scale and reflect across. obviously the capability exists since it is in the dialogs for those functions.
Another thing I miss is the ability to chop up shapes like ellipses and rounded rectangle and join them to other paths, so a convert to bezier path command would be great.
I have gotten tired of waiting for the gargantuan beast that illustrator has become to launch every time I need a little graphic, and Intaglio looks like a good solution.
Ditto, coming from a long time Canvas user…
At least, for “rotate/scale/shear about”, next to
X-position
Y-position
could there be “five points” like
o o
o
o o
on which to click to determine the center of rotation/scaling/shearing?
While I am about it: I use Flip Horizontal and Flip Vertical a lot
but, at least as often, I use both flips to get a point symmetry. So,
how about Flip Both Ways?
But, say I wanted to dilate a copy of a circle and keep it concentric with the original. Can of course be done but
Hold down the option key as you click on a resize handle to scale about the object’s center instead of the opposite corner or side. This also works when creating several path types (e.g., rectangles and ovals).
WHat do you you mean by path tyypes?? Is that what they mean by path files? Iow, if I want to shape an outline of a text, wait.
say I have a pool service, they want to advertise their cleaning offer . Just website, toll free phone # and a price. (I am making this up to fit my problem…)
so I want to have a 10 and a half inch wide ad , shaped like a swimming pool in light blueish green background in stead of a rectangle like in a local newspaper. The TEXT of the ad copy would not know that the shape of the colored background was not a garden variety text box or frame, would it? so how come I can’t get this to work?
I’m a little older; I had to take computer science for my degree but I don;t understand what the apple geniuses are talking about, and the books don’t tell you how to do what I am trying to do…
Subject: Re: Rotate,scale and reflect origin points and convert to bezier
To: email@hidden
Date: Tuesday, July 1, 2008, 1:40 PM
When I mentioned creating different path types I was referring to the path creation tools such as line, rectangle, oval and round rectangle. These tools are create varieties of a graphic type called a path. A path is just a collection of lines, curves and arcs that form a shape to be filled or stroked (i.e., outlined).
I’m not sure what you’re trying to get to work with your swimming pool example. If you want the text to flow into a non-rectangular shape, that’s not a supported feature in the current software.
