Save FTP Settings Without Uploading
Is it possible to save FTP settings without actually doing the upload?
I had some wrong info for an FTP in a particular site and wanted to update it with the new info, but I can’t seem to do that unless I want to upload it right then.
Any way to save without uploading?
Thanks…
Bob
This should be as simple as filling in the new info into the Upload dialogue box under Document Setup.
OK’ing out of the box and then saving the file.
Well, THAT was easy!
Thanks. Guess I never thought to look there…
Bob
Try File/ Document Setup/ Upload tab. You can change the FTP details here and
they should be reflected in the upload dialog next time you FTP the site.
Quoting Robert Bovasso email@hidden:
right then.
Extend Freeway the way you want with FreewayActions.com
http://www.freewayactions.com
