I am trying to write a simple script and need someone to point me in the right direction. I need to create some text, apply a gradient to it and then rotate the gradient 90degrees. My script looks like this: tell application “Intaglio” activate set myText to {make new text block with properties {font:“Impact”, size:24, text color:{linear gradient, 0.0, {rgb, 1.0, 1.0, 1.0, 1.0}, 0.5, 1.0, {rgb, 1.0, 0.0, 0.0, 1.0}}} with data “MyTestString”} set {X, Y, textWidth, textHeight} to the bounds of myText set gradient points of myText to {{X, Y}, {X, Y + textHeight}} end tell However this fails because it cannot get the bounds from myText. Any Help would be appreciated. Rob
I have got a result for this problem, although I am not really sure
why this method works and not the first example:
activate
set thisDoc to the front document
myText convert to path
set theSelection to the selection of thisDoc
set myPath to item 1 of theSelection
set {X, Y, textWidth, textHeight} to the bounds of myPath
set gradient points of myPath to {{X, Y}, {X, Y + textHeight}}
end tell
My apologies for the formatting.
I know the problem has something to do with the way I reference the
graphics (and a lack of applescript knowledge).
I suspect there is a very simple solution/explanation?
Can anyone help?
Rob
be appreciated. Rob
Intaglio mailing list
I had to look at this for a while before it made sense. The problem is that you’re setting the variable myText to a list and trying to treat the list as a reference. You’re saying:
set myText to {make new text …}
so the brackets here are creating a list containing a reference to the text object. You can’t get the bounds property of a list so the script is failing.
To fix this you should remove the brackets:
set myText to make new text block with properties {font:”Impact”, size:24, text color: {linear gradient, 0.0, {rgb, 1.0, 1.0, 1.0, 1.0}, 0.5, 1.0, {rgb, 1.0, 0.0, 0.0, 1.0}}} with data “MyTestString”
