My aged (or is it addled - or both) brain doesn’t quite see how to put the two Actions together, so that submenus expand from each main topic. A simple step-by-step guide would help, if you have the time, please.
Colin
On 13 Mar 2008, at 08:13, Steve Cooper wrote:
I’ve successfully duplicated this effect as Joe suggested – a combination of Scriptaculous and CSS Menus. It works just fine!
Thanks for the tip, Joe. I’m very likely to use this in a new site design I’m working on.
Steve.
On 13/3/2008, at 3:14 AM, Joe Billings wrote:
You can quite easily recreate something like this with a combination of either Scriptaculous/Mootools and CSS Menus.
Hi Colin,
I had written a description of what I did, but in checking it out have discovered a major cosmetic problem that seems to affect only Safari. It’s proving very difficult to resolve. (I may ask for help here soon.) When I’ve figured this out I’ll explain my method to you.
