I have used a Scripty Accordian on this page, it works fine in IE7 and IE9 but not in IE8, is there something I can do to fix this as my client wont let me make the site live until I do so?
I’m surprised it works on any browser: there’s duplicate versions of Prototype and Scriptaculous in the head of this page (both libraries are loaded twice). The older versions load last, which breaks IE, although I thought it was IE9 that it had particular problems with. It’s probably related to that. What other Actions have you applied to this page?
Hi Walter, I have use the Carousel Action, Fill Master, Rollover, Facebook Like button and Twitter Follow button, currently using Freeway Pro 5.5 as had issues using 6.0. Now going to use 6.0 to see if that helps!?
Curious. Could you please make sure that you have the very latest version of Scripty Accordion? Check on ActionsForge.
I definately have the latest version of Scripty Accordion. I have now opened the site in Freeway 6.0 and it appears to have solved the problem, but now it has broken my Carousel, so fixing that now.
If you’re in Freeway 6, then I recommend you use Carousel 2, which is a stand-alone Action, separate from Protaculous.
