Tychain
(Tychain)
November 17, 2014, 3:32pm
1
Anyone with an ipad / iPhone care to test this for me? It’s not working on my ipad2. The only way it will work is if I manually refresh the page. Works fine in Safari on my desktop.
Any reason these 2 wont together on the same page?
I tried scripty lightbox2 inside Scripty Fader and that didnt work at all, hence the little red dot. : )
Any help would be appreciated.
Dave
http://catalogsthatsell.com/DadsSiteUnderCon/originalwatercol.html
It may be because you are actually loading 2 different versions of Prototype
I would remove the reference to the older version (1.6.1)
<script src="http://ajax.googleapis.com/ajax/libs/prototype/1.6.1.0/prototype.js" type="text/javascript">
And try again.
Just noticed this:
“here the nearby ponds and rivers of New England fill my pallet.”
That is a lot of fish!
Tychain
(Tychain)
November 18, 2014, 5:50pm
4
Thanks Dave,
So, how do I get rid of that? I see it in the HTML and I could manually delete it but is there something in Freeway that I need to change? I dont want to have to do this every time I reload the site.
Dave T
waltd
(Walter Davis)
November 18, 2014, 5:53pm
5
What other Actions do you have on the page? Some combination of Actions will result in these two libraries appearing when only one should be there.
Tychain
(Tychain)
November 18, 2014, 5:59pm
6
Hi Walter
CSS menus, Scripty Fader and Scripty Lightbox2
Dave
Make sure that all your actions are the current/latest versions.
Each action window should display the version # in the bottom right corner - visit ‘The Forge’ to see if that version # is the latest.
