I’m preparing a site revamp using ScriptyFader action from Walt, thanks
Walt.
I’m using it to put quotes/pix from visiting musicians, some quotes are
short and some are much longer, I expect it would be quite difficult to add
the code be able to set an individual time for each panel in ScriptyFader
Option?
Another question, previously in the site header I had the logo and as a
rollover the address and timing details. After I rebuilt the site header to
have the SF action I tried to do the original rollover, it did not work and
I had to completely rebuild the SF set because the action would not trigger
even after removing the rollover. Would these consequences be expected?
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
thanks
Walt.
are
to add
ScriptyFader
Option?
The time has to be the same for all frames of the effect. There is a
single function that triggers the delay, and once it starts going, its
duration is set.
as a
header to
work and
trigger
expected?
Not unless the header elements were actually in the faded elements. If
you have a link to a page that shows this problem, please post it. I
can tell quite a lot from watching it in Firebug, and without seeing
it, I can’t give you any suggestions how to fix it.
Walt.
to add
ScriptyFader
Option?
duration is set.
header to
work and
trigger
Walt.
to add
Option?
header to
work and
trigger
