Hello,
I’ve been using Scripty Light Box with no trouble…until I added some new pictures to a photo gallery.
I’ve got thumbnails set up in a table, inside of an html item.
The thumbnails are are all linked up to their larger self, using the ‘graphic link to file’ action. Scripty is applied to the html item. The last 4 photos will not open…from what I can see haven’t changed anything in the set up.
Does anyone know what I’ve done wrong.
The last 4 files (the raw large files, that is) have a filename ending
in .jpeg rather than .jpg. The version of SL that you are using has a
bug in that it considers that extension to be a page rather than an
image. Very short-sighted of the original author, in my opinion.
Coincidentally, I am working on this Action today, and hope to release
an update later in the day.
For the very short term, just rename those four files (the originals,
on your hard disk) so their filename ends in .jpg, make sure Freeway
notices the change (you’ll see a bullet next to the page name in the
Site pane that they are linked from) and upload again.
On Jun 5, 2010, at 10:49 AM, Rich Gannon wrote:
Hello,
No, I should have. I looked in my current version of SL here, and the jpeg extension is added (and was added quite some time ago, so I wonder what version you’re using), but then I’m also working on other updates that should fix a general timeout problem for some users, and so I don’t want you to have to go through downloading two updates in a row.
Watch this space for an announcement when I’m done testing these updates.
