Has anyone used Scripty Lightbox and .swf files? I tried it (the same as with QT files) and nothing showed up in the lightbox.
Thanks.
Thanks.
Were you viewing these locally? Did you check, if you’re using Safari 3, under View > Activity to see if it was missing anything or any item had a “not found” status?
Everything is there. BTW, Activity is under the Window menu.
I viewed it in the browser. It flashes the movie briefly and then it is blank.
Wanted to find out if anyone has successfully used .swf files with the Scripty Lightbox to see if I am doing anything incorrectly.
Thanks.
I figured out what was going on. The .swf file I was using had a problem. When I converted the QT movie with Video2SWF I used an incorrect setting.
So, Scripty Lightbox works fine with .swf files!
Glad you got it figured out. I think it was early in the morning on that post, so excuse the menu mishap.
