Thanks Walter,
sorry for maybe missunderstanding you, but are both effects (scroll and slider) combinable? Something like:
var scrollee = $(‘slide-content’)
Or do I have to use either the one and the other?
And what about the mousecursor-issue.
Thanks for your patience.
On 13 Sep 2010, 12:02 pm, waltd wrote:
I made an example of a click-to-smooth-scroll effect here: Endless Scroll
This was an extension of the endless scroll effect: Endless Scroll
so it doesn’t use the Freeway Actions at all. But it does show that
the effect can be made to work, and in both directions.Walter
On Sep 13, 2010, at 7:37 AM, Thomas Kimmich wrote:
Hi Walter,
walked through this list and got this as result:
http://www.kimmich-dm.de/kunden/michaelmeier/index.html
I think - basically not too bad.
But I miss a few things that I should also build in and no idea how:
In your sliders, mouse cursor changes to the hand (or pointing
finger). In mine not. Äh why?You talked about event scrolling (smooth, scroll to). What’s the
trick behind and could it be implemented too?The most problems I see is in the “Touch Technologie” and it’s
fizzling kind of use the slider. The target audience will be some
Art-Directors of the world (Film and Advertising), so I think,
they’ll use it extended as I apprehend.Apple page “turns” its design from slider to arrows (forward and
backward) if it is an iPhone or Touch or whatever. Now I think this
is pretty much complicated to achieve. But is there a way to make
something between, like the prev and next in the carousel, so user
can finally decide the way he wants to scroll the gallery?Happy on any thoughts.
