Hi guys
I have been reading this thread hoping for some help
I have scrolling images displayed in an iFrame, works great now, but the scroll has no stop mechanism… and the arrows disappears as page moves so one must wait til the end, and can not stop it.
Please advise.
Thx so much I am new to Freeway Pro, have been using Express for too long
Which I think would be better suited to what you want to do.
Create an HTML layer item which your content will scroll inside - apply action Scroll Layer
Create another layer item that you put your scrolling content inside and apply Scroll Content action.
Create graphic up and down arrows and apply scroll button action to each.
Set parameters for all three actions (which are contained within Scroll Layer package on download from Softpress site.
Publish
On publish the content layer is not displayed on the page (so it doesn’t matter where you put it but better on pasteboard out the way). Instead the content is displayed in the layer with the Scroll Layer action applied to it.
The graphic arrows you created are set to control scroll up, down, stop etc.
I downloaded this Scroll layer yesterday but it was so confusing to me… I am setting up my arrows now…Are you telling me I would have to redo everything and use scroll layer to make it possible to stop?
each page has an arrow, going right and left as I was told that the arrow had to be inside the iFrame, on the page with scroll. so all my arrows lay on each page.
I work with an illustrator whose images run across the page as a scroll within the frame… The images do not look right going up and down, graphically it is pleasing. You might have thought I was using text.
