Can someone tell me how to setup a search box for items on Freeway pro 4.2.
Please and thank you
Freeway Menu > Insert > Text Field
then
Freeway Menu > Insert > Button.
That completes adding the search box and button. But then you need a script that will ‘search your site’ and add the URL of that script into:
Page > Form setup > action (with the drop down menu set to post)
There are various scripts around, Free and paid to do this including Google
or
Anyone using our hosting can (from their control panel) add/create a search script into a directory, and you have a searchable site.
You can check out the scripts available by test driving a control panel here:
http://www.printlineadvertising.co.uk/hosting/freeway-hosting.html
if anyone wants help with setting up a search script on our hosting, please contact me off forum.
David Owen
http://www.printlineadvertising.co.uk/freeway
http://www.ineedwebhosting.co.uk
Hello,
Thank you for the reply. I did excatly what you said but when I put a free google search script I end up with this error. “The Value contains to many Characters”. Can someone explain how to get the google script on my site.
thank you
Do you have a URL of the site so we could take a look?
David Owen ::
Freeway Friendly Web Hosting and Domains
http://www.PrintlineAdvertising.co.uk/freeway
This is just a test site
thanks
