May seem like a stupid question, but how do I select dropdown options from items on the toolbar, e.g. HTML, using the Magic Trackpad?
Usual behaviour of tapping doesn’t work. The only thing that works, is tap and hold down on the trackpad, then the list comes up, but it’s impossible to reach an item near the bottom as I can’t travel that far down the list with releasing my finger from the trackpad, which then, in turn makes the list disappear!
In other apps, accessing this type of list is achieved by the two-finger tap (right click), or by a tap on the actual down arrow itself, but neither of these work in FW.
I can workaround most of them, as the options are duplicated on menus, e.g. the HTML ones, but this is not always the case.
I don’t have one of the latest Magic Trackpads, but I do have the first one (with the mechanical switch). I believe this gesture will work in either, because the new one emulates the way the old one worked. Mouse over the target click point using your index finger. Use your thumb to press down near the bottom of the trackpad (that’s the click) – just as you would have done on an old PowerBook with the separate button. Continue to hold your thumb down to keep the menu open while you “scrub” through the list with your index finger.
