Normally I don’t have problems connecting to a remote MySQL db through
Sequel Pro but for some reason now I can’t and my host can’t find any
reason why. The shared IP address that was working is now denying
access. And I have my IP on the Remote MySQL access list. In Sequel
Pro I’m connecting using the Standard tab. Ideas?
Check and see if your ip address changed. Unless you pay for a static address, your ip can change from time to time. You’ll have to check this at your router’s control panel (usually a web site at 192.168.1.1) as your Mac’s ip address doesn’t count in this matter since you’re hiding behind the router.
Oh, and I just read through my previous message, and realize I may have mislead you. When I said replace the fake ip with your own, I meant to say replace it with your server’s ip.
I’m not sure what else to do. Maybe I’ll try support one more time,
perhaps they overlooked something.
I’m using Airport Utility and I see a few different addresses. Where
(under what tab) should I be looking within the utility?
Click on the Internet tab, then the TCP/IP sub-tab below that. You should see the picker for DHCP or Manual. If you’re on Manual, I don’t think this will be the issue. If you’re on DHCP, you should see the current IP address below that, although I can’t be certain because my Airport is set in bridge mode and has a fixed address, so I’ve never seen it in DHCP mode.
