I’d like to set up a light box on my site. Looking around, it seems that there are a lot of choices, if I understand what I’m reading correctly: ScriptyLightbox, Slimbox, FancyBox, Lightbox, maybe some others.
Can anyone give me a suggestion as to which might be the least complicated for me to get up and running? Also, I’d like to have captions.
I use Weavers Mootools Action Suite. Mainly because it was here first and I started using it way back when. I think Weaver is working on a modern update of sorts. Haven’t had any issues that I know of. The Slimbox (lightbox) effect is drop dead simple to use. Drag a photo on a page, apply the action, set a few options - done.
The only minor catch is that you need to make sure you add the Protaculous page action (set to Scriptaculous packed) to provide it with the necessary files to work.
