Setting up Pay Par Click
HI,
I’ve been asked about Pay Per Click systems and how would one be set up. I haven’t a clue - are there any out there which could be plugged into easily?
This isn’t a case of using Google as the system will be targeting a very narrow band of adverts. I’ll know more next week, but I’d like to get a head start on what’s involved.
dynamo mailing list
There are hundreds of these on HotScripts. Do you have any specific requirements that you can share? I might be able to recommend one.
dynamo mailing list
Hi,
at the moment, no more details. I’m looking for options at the moment.
dynamo mailing list
Here’s a list, sorted by member ratings:
http://www.hotscripts.com/PHP/Scripts_and_Programs/Ad_Management/index.html?action=formsubmit&listing_sorting_order=member_rating&listing_sorting_direction=des
dynamo mailing list
Paul,
Your using our hosting. Look at Openads (OpenX) in your hosting control Panel. One click install it into a directory and have a play around with it. Its one of the scripts Walt has kindly listed on his Hotscripts search URL.
On 2 Sep 2008, at 12:41, Paul wrote:
HI,
David Owen
(Test Drive a web hosting account for Free)
http://www.ineedwebhosting.co.uk
http://www.printlineadvertising.co.uk/freeway
Printing:: (leaflets, letterheads, cards etc)
http://www.printlineadvertising.co.uk/print.html
David - I’m not using your hosting :wink:
I’ve more information now, and really what’s needed is an online solution, not some scripts. Client is looking for a system where the clicks are counted and payments taken without him getting involved with invoicing directly. He’s anticipating a lot of traffic, but at the same time he’s not wanting to employ staff to handle the advertising payment side of his business.
He’s speaking to a company tomorrow which should be able to provide a pre-packed solution which we can just plug into from our end.
The downside of all this is that the site he’s proposing will require a CMS to do most of the heavy lifting, which make life interesting.
dynamo mailing list
Opps sorry - missed out the word “if” at the start :slight_smile:
But even so - check out open ads http://www.openx.org - although it looks like a learning curve will be needed.
David Owen
