I have just started building a site with freeway pro 5 - I have no experience with web site design at all!
We run day tours and I want to place some drop down menus on the homepage so users can see the different tours we do in different categories. For example, there would be a number of options when you click on City Tours, or Half day tours. The problem is that the width of each navigational popup is different according to how many characters are in the description. I have tried adding blank spaces to increase the length of the shortest text decription, but that doesn’t work.What I have had to do is add a series of -------- dashes into the Option 2 of each navigational popup of the same length so that all the popups are the same. Is there a way just to set the length so that it is fixed and not dependant on the amount of text?
I answered this on the main list last week. <http://freewaytalk.net/
thread/view/30564#m_30568> (First hit after your question in the
search engine on the Freewaytalk Web forum.)
of text?
