Hi. I’m using the show/hide layer action (with the sequence timer) to fade in from one image to another. Everything looks fine in Safari, but I notice in Firefox Mac 3.03 the text looks bad – like a bad Flash pixel font. Changing the layer order doesn’t help either. This does not happen on the pages where I am not using this effect. I’m publishing xhtml 1.0 transitional. Would anyone happen to know of a fix for this … or is there another way to do the transition fade effect …
thank you.
Would you mind taking a look here and let me know if you see the fonts as I do? If the fonts can’t look good with the transitions, then it just took a whole lot of fun out of this.
No go. With the code, or without it, the type stays yucky.
I even switched to a different effect: I tried the transition fx.
It had the same effect. With no transition the type looks good.
