Is there a way I can ad scrollbars to a showcase file so it can scroll within a window? Setting overflow to ‘scroll’ or ‘auto’ in the inspector doesn’t work…
Joe2
(Joe)
August 24, 2010, 2:07pm
2
Hi Adriaan,
Currently there is no way to do this, sorry.
You could put the showcase within a carousel using Walt’s action. If you are using the RPL action on the page also then you will have to use Remove From Relative Page Layout on the carousel for it to work.
This isn’t the same as having a scroll bar obviously, but similar.
Thanx! I will give it a try.
Keep in mind that you probably will have to break-up large galleries into smaller ones and then place them end to end in the carousel.
Joe2
(Joe)
August 24, 2010, 6:09pm
6
Oh the other thing you can do is put the carousel inside regular HTML item which can have its overflow set to scroll.
Good point.
Good point.
Hmmm… actually, I think you mean the showcase, not the carousel.
Joe2
(Joe)
August 24, 2010, 8:22pm
9
Yep, I do - my bad
Good point.
I have put the showcase into a HTML item. And it works fine on a Mac. Thanks! However on a PC it works with scrollbars and all, but it refuses to open the large images.
Has anyone any idea why?
Cheers!
