I have simple search on a site I am working on - it is throwing up a result for a page that did have a keyword which was relevant to search criteria. However I removed the keyword from the page which I did not want it show as a result and it still shows in return of results.
Try holding down the Control key and choosing Publish Everything from the File menu in Freeway. Then upload again. The index file is compiled by Freeway when the site is published, but it may not force a rebuild of the entire site when you remove a page. It seems to me as though it should, but that could be where the issue is coming from. It also may be that your browser’s cache is holding on to the old index file (it’s just a JavaScript source file, after all, those do get cached). Try a different browser, or hold down the Shift key while you press the reload button, or enable the Develop menu in your Safari preferences and choose Develop / Empty Caches and reload.
