On 27 Oct 2009, at 13:15, julie maxwell allen wrote:
I have switched back to the test address:
best wishes,
Paul Bradforth
best wishes,
Paul Bradforth
I did fix that too…
but any suggestions not to have the pictures move?
J
best wishes,
Paul Bradforth
On 27 Oct 2009, at 14:06, julie maxwell allen wrote:
I did fix that too…
Is it not uploaded yet? It looked the same just now.
On what page are they moving? Can you say, carefully and concisely,
how they are moving and what it is that you don’t like about that? I
haven’t noticed a problem with pictures moving myself.
best wishes,
Paul Bradforth
It is now uploaded.
http://www.grassrootsweb.net/tlc
Ok:
if you go to the 4 rooms, infant, toddler, pre, school
the pictures on the left are showing up high - sometimes under the
“roots to wings” I have them aligned on the page w the title of staff.
also, the names in the infant room, when rolled over they show high -
but in the file, i have aligned them w Miss Dorall.
why does this happen and how do I fix it.
Thank you .
I did fix that too…
haven’t noticed a problem with pictures moving myself.best wishes,
Paul Bradforth
The -home- page does not validate (Did not check the others) because you made some mistake in setting up the setupZoom() script.
Choose in your FW document: page (from the menu)–>extended–> Name: onload and -->Value: setupZoom()
(write just onload and setupZoom() in the fields, nothing else)
Because now in the source it says:
And, please, I’m kindof colourblind, the yellow with white text rollover makes me click away the page. (sorry…)
I will change the yellow… to a blue. thank you
What are you talking - validated?
setup zoom? I did what you said and took out the quotes…
can you explain please what this is?
you made some mistake in setting up the setupZoom() script.Choose in your FW document: page (from the menu)–>extended–>
and that does not validate. What it does with the script I do not know.
Because now in the source it says:And, please, I’m kindof colourblind, the yellow with white text
staff.also, the names in the infant room, when rolled over they show high
- but in the file, i have aligned them w Miss Dorall.
I can’t really say, as I don’t know how you made it. If you want to
zip the site up and send it to me, I’ll be glad to have a look.
best wishes,
Paul Bradforth
About validation:
A simple yet effective way to check if all is well with the underlaying code of your page. (I shall not discuss here the why and how, also since there is some discussion about how ‘strict’ one must be… But:
If you go to http://validator.w3.org/ and copy-paste the URL of any page, then you’ll see the result of an examination. Your home-page is now not so good. Again, how bad that is is not part of this discussion. But it’s very handy sometimes even for FW workers to check if changes have an effect. You did something with page-extended. That means you did add extra code to a normally perfect FW page. If you decide to change the code, you must also know how to write correct code. Otherwise, just do not touch that dial…
I did not know anything and did not touch it till you gave me
direction…
I dont know what happened.
did i fix it with your suggestion?
Julie
On Oct 27, 2009, at 11:23 AM, atelier wrote:
About validation:
be…But:
One other point about this. If you find that a JavaScript effect is
not working (particularly anything Prototype-driven like the fades and
other FX Actions) then your first debugging step should be to validate
your page. Prototype requires that you start from a “known good” base,
because it does things “by the book” internally. Other JavaScript
libraries most likely have this requirement, too.
About validation:
be…
ok,
That might help with the fading slideshow problem on my page?
layering the pictures?
Julie
and other FX Actions) then your first debugging step should be to
validate your page. Prototype requires that you start from a “known
good” base, because it does things “by the book” internally. Other
JavaScript libraries most likely have this requirement, too.Walter
About validation:
must be…
Julie
You best can check it yourselve by pasting the URL in http://validator.w3.org/ It’s often impossible to say anything about the why of errors without looking at the FW document.
alot of times I am righting from my phone… sorry .
Writing too…
The iPhone makes typing relatively easy considering how small the
keyboard is, but it isn’t perfect. Don’t rush, take your time…
k
Thanks! I know - fat fingers I say LOL
Keith,
I put up grids and “snapped” i think… unsure…
I feel better about it… But I think the “flow” is something that will
come with practice practice practice…
Thank you for that help…w the grids… I had some issues but what I
did was made a small grid (20 px) and used that to snap too.
What do you think?
J
can you help me with the other problem I posted yesterday please?
thx
Writing too…
keyboard is, but it isn’t perfect. Don’t rush, take your time…k
You’re unsure whether you snapped or not? Well, are things aligned to
the grid as they should be? It sounds as though you don’t understand
the concept of alignment.
best wishes,
Paul Bradforth
They are aligned…
I do understand… I guess when ever I say ok… then something goes
awry
how does it look? better?
J
to the grid as they should be? It sounds as though you don’t
understand the concept of alignment.best wishes,
Paul Bradforth
The show/hide on Child and Adult Care Food Program is also a mess - if you really want to do it that way put a border on the box and give it a subtle background colour to lift it off the page.
Better but the text is right to the edge of the box (add padding to keep it inside) and there is no border and paragraph spacing. It just looks jammed in.
Subtle background colour? - remember if you have green text on a green background it isn’t going to be easily read. It may only be one character “T” but there are other places on the site where there are poor colour choices.
Good point on the green. Is it looking better?
Ty very much
Sent from my iPhone
give it a subtle background colour to lift it off the page.Better but the text is right to the edge of the box (add padding to
just looks jammed in.Subtle background colour? - remember if you have green text on a
are poor colour choices.David
Doesn’t look any different. It needs some padding, as Dave said. Text
jammed up against the edges.
best wishes,
Paul Bradforth
Actually, why not just get rid of the pop-up altogether? There’s
plenty of room on the page for that green box to be visible all the
time; it’d help to fill up all that space.
best wishes,
Paul Bradforth
