Site help
Hi…
Looking for some critical feedback for my website. It needs … a lot of things.
Also, Looking for some US contacts for bouncing ideas around. (I’m in Denver, Colorado)
Thanks much!
Kelly
Ummm… what web site?
Duh…that might be helpful!
www.ip5280.com
I’m aware that I’ve got a few links down in documentation and a flash issue on the home page. I think I have a problem with the tech support form in Firefox. Otherwise, looking for some recommendations on layout and some actions/other enhancements or any other comments you can provide.
Hi Kelly
Well visually I think it is quite appealing but there a couple of things that I have noticed.
Firstly you have a lot of Graphic text and a lot of the same alt tag repeated endlessly
alt=“Denver Colorado Business VoIP IP Phone IP5280”
I don’t know much about this but it may be regarded as SEO spamming it is repeated so often.
To be more SEO friendly I would get a lot more HTML text in there and vary the alt tags before you get penalised.
Also the About Us page seems to align differently to the others - I think there may be something off to the right on that page that stops it aligning centrally.
Thanks, David…I appreciate your feedback. I was wondering the same about the alt tags, but I wear too many hats and haven’t had time to spend adjusting it. The tips on Graphic text are good too.
Thanks for taking the time to take a peek.
Kelly
One thing I think would help is giving your menu bar a rollover effect. I think a change in background color would be enough so that browsers will have a sense that something is happening. The change in cursor is a clue, but i’m not convinced that’s enough.
