Hey all… one question… I made a slideshow with sequence timer etc and I have one question about the stack of layers where I have a text box underneath to describe the item…in graphic. It is easy to edit an imported graphic on bottom layer , once you highlight it there is a middle one can go in adjust, but the little text box I can not get to. to make any changes if necessary…
The only thing I can think of is taking that bottom layer HTML box with all layers and move it on top, edit and put it back underneath. When i highlight the child (text box) I can not highlight it… it jumps to the top layer
or is there an easier way?
Select the text box in the Site Panel on the left. Press Return. The
text box is brought into ‘focus’ and you should now have a flashing
cursor in you text.
Also, for Graphics - you can select the item in the same way and use
the shortcut key ‘Option-Shift-Command (Apple) and M’ to open the
dialogue box for resampling, changing or editing out side of FW.
Colin
