Slider for freeway pro7
I am looking for a non code slider with multifuncions to buy for my mac…the alternative is to use imovie to create the same…because i have made movies…although i dont know if it is formatable for net or size adjustable?..
http://wowslider.com as one of several possibilities.
It should be noted that it creating is for (code) free - implementing is another topic. But I’m sure you are aware of.
