Dear Walter,
I wrote you a few days ago about a problem i have.
I’m trying to to build a site that uses smooth scroll and carousel effect together. You can see in the link that i’ve attached that if you press on the right or left arrow of the carousel the pictures moves ok but it also move up. Is it possible to do what i am planning?
I will have to make some changes to SmoothScroll so it will reject the Carousel2 elements. At the moment, it only works with Carousel (original) because Carousel 2 doesn’t use the same classname on the link wrappers as Carousel. Simon Manning rewrote Carousel for Freeway 6, so you may want to give that a use in the interim.
On Feb 15, 2013, at 4:16 AM, Hanan Diamant wrote:
Dear Walter,
Vey nice. How did you get the scroll behind menu bar? I assume the menu bar is fixed in place, but would be interested in how the vertical scroll is done.
