One thing you could try is to substitute ScriptyFader for other
effects. As much as you love the Carousel, and as neatly as it maps
onto the product you’re advertising, it suffers from the limitation
that all of the elements it shows on screen are part of the page, and
thus contribute to the overall page weight. The same thing is true of
the Fading Slideshow effect.
ScriptyFader, on the other hand, does an Ajax request for the next
animation element if it hasn’t been loaded into the page yet, and thus
the initial page load is limited to just the currently-visible
elements. Each additional frame is requested and added to the page
just as it’s needed, until all of the elements are loaded into the
browser’s memory. (This technique is sometimes called lazy-loading.)
But this brings with it a different trade-off – because those
elements aren’t in the page at the initial load, they are not
considered for SEO purposes. Since all you’re loading are pictures,
there’s no loss. But if you were loading in news stories or other
content that you wanted to have a chance with the search engines, then
you would want to pick something else.
On Mar 25, 2011, at 1:38 AM, Valerio Do Carmo wrote:
Thank you Walter!
Before I finish the last message I pressed send by mistake…sorryWalter, I’ll try to lower the size of all images and the backgrounds
also. I expected that this kind of page would be bigger than a
normal one, but the idea is to load it faster too. Besides lower the
size of the images do you have any suggestion to get the page smaller?I appreciate your help!
Marcus
On Mar 25, 2011, at 12:42 AM, Walter Lee Davis wrote:
I think it has to do with the enormous size of the page. All of
those fading slideshow images take time to load in, and until they
do, the page isn’t done loading so the setup event doesn’t fire.Walter
On Mar 24, 2011, at 10:57 PM, Valerio Do Carmo wrote:
Dear Walter,
The carousel action is working perfectly, together with the
Protaculous instead of the sound fx action even in IE, but
curiously I have noticed some hiccups on the page with Firefox and
a minor one in Safari.This is the link. Please take look. It’s still a working in
progress:
http://www.sunshinedoorsspecialists.com/new/site/index.htmlThis website is the one I’m using the carousel action as pages. On
the carousel action I notice some delay on the carousel tab. In
safari at first, It takes about 2 seconds to the carousel to move
to the next panel after you click with the mouse. On the other
hand in Firefox after you click on the tabs the URL changes
sometimes to something like: http://www.sunshinedoorsspecialists.com/new/site/index.html#panel-2Do you have any idea how could I adjust it?
Thanks in advance,
Marcus
On Mar 22, 2011, at 10:22 PM, Valerio Do Carmo wrote:
You’re right Walter.
Thank You!M
On Mar 22, 2011, at 10:15 PM, Walter Lee Davis wrote:
I don’t think you really should, Paramount is quite litigious.
I’m going to take it down soon so I don’t get given the Red
Shirt treatment by their solicitors.Walter
On Mar 22, 2011, at 10:07 PM, Valerio Do Carmo wrote:
Walter, that Enterprise lift-door woos is very nice! Can I use
it?best,
MarcusOn Mar 22, 2011, at 9:53 PM, Valerio Do Carmo wrote:
Hello Guys!
Even though I also got the 403 with noisy link, I could
download the FW file and used and “voila”!! It works for me too!Walter, thank you very much! It was giving me a little headache.
Now I’m back to businessMarcus
On Mar 22, 2011, at 9:26 PM, DeltaDave wrote:
Hi Walter - getting a 403 on your noisy link.
