When the static layer is applied to an item, it looks a little ‘jumpy’ when you scroll down the page. Is there a smoother method available does anyone know?
Nathan Garner
FW5 Pro | MacBook Pro | Leopard
does anyone know?
If you can get your visitors to use a proper browser, then you can simply set position:fixed on the element in the Inspector. But IE < 7 doesn’t recognize this much at all. And I think 7 has some issues with it as well. Maybe IE8 gets it right, but somehow I doubt it.
Otherwise, if you need to maintain the illusion (for your visitors) that IE is a standard Web browser, you have to put up with the JavaScript trick that keeps the image positioned a certain distance from the top of the viewport. And that will be jumpy in most browsers.
Thanks Walter - I suspected as much with IE.
Nathan Garner
Partner
Member of NAPP
does anyone know?
There are hacks and emulation techniques to get around this in IE6
and below, albeit with tradeoffs in one respect or another. If you
want to get knee-deep in it try searching Google for “IE position
fixed”, you’ll find a lot to keep you busy. Here’s one of many
examples, http://www.howtocreate.co.uk/fixedPosition.html.
That’s interesting, Todd. The author of the article you linked says IE7 respects position:fixed only if the DTD is set to strict.
examples, <http://www.howtocreate.co.uk/fixedPosition.html>.
Ernie Simpson – Freeway 5 Pro User – http://www.thebigerns.com/freeway/
Some of the IE position: fixed solutions I’ve experimented with have included [to me] interesting aspects and this is one of them.
