I’m trying to get a weather widget to work in a site, and am really struggling!
I am pasting code generated from sites into the Extended menu of an html item as a new div.
Some widgets semi work, some just produce errors and some just have some text in.
Any help?
I solved it. Obviously, I should have been putting the widget in as a Markup item, and not putting the code into the Extended item menu.
Insert > Markup Item - is the way to go with these sorts of things.
The Markup Item will then appear on your page and you can resize and position it to suit your layout.
Thanks Dave. That’s what I did. I was previously entering the code into the extended menu of the item. Duh!
