I’ve drawn a table on my site and am not seeing where I can style a link in the table. Can you point me in the right direction?
You could create a set of link styles, targeting tables. Create link styles in your Style editor, named :
Apply the desired properties to them and you’re all set.
Richard
link styles can be set in many places
Globally (ie page wide) - with nothing selected on the page look in the Inspector under the Paintbrush icon for the Link section. set styling in there.
There are also various actions - what version of FW are you using? Express or Pro?
Hi David! I’m using pro
There is the Text Link Style action - it certainly used to come with FW
Select your Item>Actions>Text Link Style
If you dont have it then we can send you a copy.
