Thanks Walter, there a way to see the effect on the main menú?
thank you very much for the help
Enviado desde mi iPhone
El 22/02/2013, a las 07:13, Walter Lee Davis email@hidden escribió:
You’ve set everything up correctly in Protaculous, the only issue I see here is that there aren’t any submenus in your main menu. There’s only the top-level options. You need to set up your sub-options for each main option, by nesting a second-level list item below each one.
On Feb 21, 2013, at 10:30 PM, jgalicia wrote:
thank you.!! but it does not work, this is the site produce.mx / index
The effect only happens on the submenu options. There’s no disclosure on the main menu unless there are submenu options – nothing happens when you mouse over the main menu options that could be altered. You may want to investigate CSS3 Animation to alter the speed with which the mouseover highlights happen in the main menu options, but that will only work on recent Firefox, WebKit (Safari, Chrome, Opera), or IE 10 browsers.
