How do you get a submenu to be the exact same width as its main menu item above it?
URL where site’s located:
thanks.
thanks.
Try this
In the Submenu Settings section of the action interface select - Use Main Menu Settings
Now this will only look right if you have made the main menu settings wide enough to accommodate the width of the largest/longest text in the sub menu
BTW - the white text is very difficult to read against the yellow background.
Still not working for me… it’s extending about 6-8 pixels to the left (into the main menu item just to its left).
Delta… Thanks Dave. Working fine now. PS: The yellow menu header background looks fine on my system screen. Thanks for headsup tho.
Regards.
Maybe - but you have to take into account what the rest of the world sees! And a lot of them will have cheap PC monitors where colour accuracy is unknown.
