I have a table (two columns, one row) and I insert an HTML item into the second column and in Beta 2 added a border-left 1px solid to the HTML box then my color choice. I open the file today in Beta 3 and the whole html box has a border and when I go into inspector it has an eye with a slash through it on it and the border options are un-selectable.
When I load up my code it shows the published code as adding a 1px border around my HTML box. I remove the HTML item in question and replace it (with the same thing essentially) and set my border left again and publish and it still adds a border all the way around.
Why is that?
(I tried setting a id DIV tag to have a border or no border-style and it didn’t work)
3 - Inside the parent drawn HTML item insert three child HTML items.
4 - Doesn’t matter on setting float or anything
5 - Allow the parent to have an undefined height
6 - Apply a custom border to either the top, middle, or bottom child HTML items.
7 - Publish and the whole child HTML item has a full border (all sides) and your border options are grayed out in the side bar. A black and white eye with a red slash through it exists and there’s no way to get rid of it.
It worked fine in Beta 2, but is broken in Beta 3.
