I have a text box where I want the overflow to scroll. I copy the text into the html and can’t seem to keep the box the correct height on the page even though overflow is checked to scroll…what am I dong wrong?
Are you in Freeway 5 (beta) or 4? If the former, do you see this
while you are clicked on the box in question, or after you click off
of it?
If you are in Freeway 4, you have to use an Action to get this
effect. The problem is that Freeway 4 helpfully will not let you draw
an HTML box with overflowed content, it always adjusts the height to
fit the contents.
I am using 4.4.2. waiting for the final release of 5. As soon as the text enters the box from pasting it lengthens. This HTML box is tagged overflow, scroll. Anyway around this?
